Turn Signal Wand / Stick Wiring Diagram
  • amcordo
    • Jun 2009
    • 740
    I know I've seen it but I spent last night looking through search results and couldn't find it. Anyone have the wiring diagram for the SIII turn signal wand? http://www.roversnorth.com/store/p-2...d-ser-iii.aspx
    I've got two of them sitting here with wiring coming off of them, but I'm not sure what wire does what... THANKS!
    It's all right here. Just check items 25, 30 and 3. They're all part of the wand.
    • amcordo
      • Jun 2009
      • 740
      Thanks, but this isn't what I was talking about. I'm looking for a diagram of the stalk itself. I know I've seen it - one that shows the stalk and which wire that is coming off where goes to what...
        Um...OK. The diagram, for example, shows that the blue wire comes off the wand and goes to terminal 8 on the light switch, The purple wire comes off the wand and goes to the downstream side of an "always hot" fuse, etc.
        What other information are you looking for? The electrical flow within the wand assembly itself?
        • amcordo
          • Jun 2009
          • 740
          Yessir. These stalks don't have the original wiring.
          • Les Parker
            • May 2006
            • 2020
            Wiring for Series III
            The indicator switch is item # 30
            Hope this helps,
            Les Parker
            • kevkon
              • Aug 2009
              • 364
              You mean you have two oem stalks with the wiring and plug, but no harness adapter?
              94 D-90 tdi
              72 Series III
              • amcordo
                • Jun 2009
                • 740
                They've got wires coming out of them (no plugs or harness stuff), and I'm rewiring my whole rover with a modern fuse box and relay system and better connectors.
                I'll just go through the wires and figure out what does what myself tonight; I was just hoping to avoid reinventing the wheel.
