I scored a truck cab from a friend that is in great shape, the only problem is I just have the top and rear part with no hardware or anything else. My truck is set up for a soft top now. What do I need to do to make it work? I test fit it the other day and could tell that the hooks on the top of the windshield need to be removed and the rear part didn't seem to sit right on the bottom. Is it possible to switch from soft top to truck cab and back again?
Soft top to truck cab switch
1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSETags: None -
Yes it's possible to switch between soft top, truck and hard top and back, no problem, I switch between hard top and soft spring and autum, the top-windshield-rail has to be removed, to fit the truck cap or hard top, so you need to drill out the poprivets, replace with flatheaded screws. -
There is also a bottom spacer bit that needs to be in place for the the 88. The 88 requires it and the 109 is such that the p/u top just sits squarely on the rear bulkhead.Firemanshort
1980 Stage One
On my 88 I just stuff a blanket in there and it worked for years. I think rn has that part anyway if you need it.Comment
I have a 109 so looks like it will work. Thanks for the info!1970 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
346325 Cab adaptor
RN is in the process of re-supplying this part for the 88" Series cab tops.
Also the support bracket # 330767 .
Watch this space !!!Les Parker
