PRIMARY PINION: The primary pinion and constant gear on my IIA suffix C transmission look OK to me. I am planning on replacing the bearings and reusing these items. The oil scroll on the pinion is fine.
I guess the reason I'm posting is there is slight wear on the base of the pinion, where the inner sleeve of the bearing rests. It is not 'feelable' just visual. I shouldn't even call it wear, more like 'marks' of where the bearing sat.
I'm assuming this doesn't constitute the 'obvious wear' that the green bible clumps everything into.
CONSTANT GEAR: afew tiny chips on the teeth. I've circled a good example. Same thing right? No heavy gear wear or chipping so guessing it's fine.
