I have a 73 Series III 88" Petrol. Engine rolls over fine but won't spark. I don't seem to be getting spark from the coil. I have replaced the ignition coil, condensor, cap, plug wires and ignition switch already. Still no spark. Any thoughts? I am at a loss.
Ignition Question
Welcome to the forum. Sorry to hear about your ignition issue. We'll assume this did run at some time in the recent past.
Are you getting voltage to the coil?64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucks -
Alright. The update is as follows. Replaced the points, no change yet, however I am going to go back and check the "power wire to the points" as suggested. (I ordered all the little stuff that typically seems to fail as a safe measure and have gone through slowly replacing each part and testing the results - if no change I keep the old part because it may still be good). I'll keep everyone updated.Comment
did it last weekend. and i've done many times
to check clip the gator clip of a test light to the low tension lead on the coil that the one with the wire that goes to the points. turn ign on. touch test light to the wire right where it is connected to the points. with free hand open the points. light should go out.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
Fixed
Spent Saturday staring at the truck until I couldn't handle it anymore and then took a much need beer break for six hours..... Got back to it Sunday morning and realized I am an idiot.... points while new, weren't set to the correct gap because I didn't check it... I then checked the timing (which was out) and she is up and running again.... the engine, not the truck. Clutch next weekend
