I have a new front and rear rebuild kit form AB...to go along with my new brake MC and brake lines. After I bench bleed the MC and all four brakes...after driving a bit and applying the brakes i lose pressure. SO, i went back to the house and check. The rear left tire is covered in dot3. Checked the bleeder valve and everything is tight. Removed the brake drum and the wheel cylinder is leaking.
I would think that its a faulty wheel cylinder...but this is the second one. The first one did the same thing. Whats going here? The other three are fine... just the rear left wheel cylinder.
