! Need Mesurements for Door Frame for Welding
  • amcordo
    • Jun 2009
    • 740
    Hi all,
    So I'm about to get my parts back from the chemical stripper and as expected both door frames split in half at the rear column where sever corrosion had occured. I need to take them over to a welder to get them fixed up. BUT I failed to take measurements before hand (duh) and now desperately need them. Can anyone tell me what A, B, and C are so that the welder puts this together perfectly?
    Thanks!
  • amcordo
    • Jun 2009
    • 740
    Bump. Anybody?
      Is it something that can be measure in-place on a fully assembled rover? If so, I'll go out and have a look.
      • amcordo
        • Jun 2009
        • 740
        You should be able to - it'll be hidden under your rock sliders if you've got them, but that's where this door frame is.
        • amcordo
          • Jun 2009
          • 740
          Rovers North boys - do you guys have the schematics for these things? I'm in desperate need because I've got to make sure they're welded back correctly and they're nowhere near my rover to test them before doing the welding and galvanizing.
          • Les Parker
            • May 2006
            • 2020
            By golly, we have a set of new parts here.
            Please call me and I'll get the dims. for you
            Les Parker
