Anyone know where I can find cam/valve timing data on a 2.5 engine? Not sure if I'm using the right terminology, but the kind of info I'm looking for is:
At ___degrees __TDC on the intake stroke, the intake valve begins to open
At ___degrees __TDC on the intake stroke, the intake valve is fully open
At ___degrees __TDC on the intake stroke, the intake valve begins to close
At ___degrees __TDC on the intake stroke, the intake valve is fully closed etc.
Just trying to figure out if briefly being off by 7.5 degrees on my timing belt swap 5000 miles ago could have caused the exhaust valve strikes on my pistons.
