IIA pieces of flare
  • shock
    • Mar 2010
    • 24
    IIA pieces of flare
    For some reason I've been under the impression that my 1966 IIA brake lines have bubble flares. But after rooting around the forum I'm having some serious doubts. Could it be that there's a mix of flares by a previous owner? A couple of the lines are shot so of course, I want to get it right. Thanks.
    -Scott
    '66 88 IIA
  • Bud
    • 21
    Every Land Rover should have at least 23 pieces of flair. Bear in mind that this is not a requirement, we want you to want to show your flair. It is your choice if you want to do the minimum, but...
    In all seriousness, all your flares should match. If they don't, then you're probably better off using the correct (new) parts and walking away with peace of mind.
    • gambrinus
      • Jan 2007
      • 142
      If you're mirror falls off, no big deal. If your seat wobbles, no big deal. Certain things you can "sort of" get right, other things WILL KILL YOU if you screw them up. If in doubt, go to a mechanic when dealing with your brakes.
      RW
      • shock
        • Mar 2010
        • 24
        RW
        I appreciate the comment and I agree with the sentiment. I've done brakes on a vehicle before (and I'm still around). I'm just looking for clarification on what is the norm for a IIA.
        '66 88 IIA
        • 4flattires
          • Aug 2007
          • 424
          Nice!
          I got it
          64 SIIa 109 all stock
          69 SIIa 88 all stock
          Old tractors
          New Harleys
          Old trucks
          • alaskajosh
            • Sep 2007
            • 208
            I think you want a double (not bubble) flare on everything. I can tell you first hand (due to a previous owner's mistake) that a single flare is NOT the ticket. But there is clearly a male/female thing going on inside the fittings contra-indicating a bubble flare.
            Anyway, I did double flares throughout and expect to die of old age.
            Kind regards, Josh
            • JackIIA
              • Dec 2008
              • 498
              whoa
              sounds like somebody has a case of the Mondays!
              sorry, I couldn't resist, given the day.
              1970 88 IIA
              • shock
                • Mar 2010
                • 24
                Update: I decided that since a couple lines were shot I should replace all of them. I ordered a set of Automecs. They all have bubble flares. Hopefully this post helps someone in the future with the same question.
                '66 88 IIA
                • daveb
                  • 513
                  really? post a pic. then a pic of the inside of one of your wheel clyinder ports.
                  the automec kits are questionable and don't always correspond to US model vehicles.
