Pardon my ignorance but this may be a stupid question. Does the clutch disc get bolted to the pressure plate? I ask because I think I have screwed this up and now can't get the truck into gear. Here is my play by play. I did this once before but it was many years ago and I can't remember if I did it wrong then too, needless to say, the truck hasn't driven after either attempt.
After everything was removed I did the following.
Which sequence is correct? Your help is greatly appreciated.
- Bolted the clutch disc to the pressure plate (using the three bolts on the perimeter of the pressure plate that have tabs on them)
- Aligned the pressure plate/clutch disc assembly with the engine using the tool
- Reconnected the transmission to the engine.
