Carb rebuilds
  • utahseries
    • Apr 2009
    • 155
    Carb rebuilds
    Who does everyone recommend to rebuild their carbs? Solex and Zenith? Most of this is just curiosity FYI
    1956 86" S1
    1957 88" S1
    1967 109" SIIA NADA
    2007 LR3
  • siii8873
    • 1013
    Rebuilding a carb is not terribly difficult to do yourself. Essentially removing old parts and replacing them with new parts. With the zenith i would include lapping the faces or the cases where they split. I used a piece of float glass and some 600 grit sand paper to do mine. It got rid of the Zenith warp that mine had. The bulletin on zeniths at the top of this forum is also good for setting them up after the rebuild.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
    • Donnie
      • 287
      If U don't want to do it youtself.........................Joe Curto
      • xsbowes
        • 258
        I also found the zenith quite easy to rebuild. Use a sharpee and color in the faces when you go to sand as above. once the color is gone you should be good to go on the surfaces.
        Stacy
        Motta S.A. Italy
