I just installed a Dusfold rebuilt transmission / t-case in my Series IIA. All seems to be working fine, except for a small amount of slop. This occurs during the relaxation period between shifting gears and also when you lift your foot off the gas to coast. Adding the gas back in picks up the slop and it clunks again.
The drive shaft u-joints seem ok and the rear 3rd member pinion seems to have normal free play. There is a small amount (2 inches) of free play off the rear output housing when you try and spin the transmission brake. I removed the rear drive shaft and drove it in 4WD HIGH with only the front drive shaft on. It did basically the same thing.
I took some iPhone videos to show some friends:
and
Some say to put the floor boards back in and just drive it that this little bit of play can be normal. Others say to maybe have something checked by someone who knows more.
Any additional insight on this?
Thanks,
Jamil
and
Thanks,
Jamil
