Ser III Park Brake design
  • TJR
    • 279
    I assume the Ser III Parking brake is similar in design to the prior series rigs, but as I'm cleaning my up for paint I can't beleive how much engineering and quailty went into this typically simple contraption. My rear axle shaft may snap, or my frame rust out, but the PBrake will survive 37+ years w/o ever being touched.
    All the "bits and bobs" are from an era we'll probably never see again.. Solid cross bar. bronze (not plastic) self aligning bushings with felt seals, 1/4 thick pawl plate, solid cast bell crank, Thick frame brackets, one is CAD plated. spring loaded cross pins.. Amazing.. and seemingly over engineered.
    I guess the bean counters never had a chance to push engineering/manufacturing to design the cost out of that linkage.
  • bmohan55
    • Sep 2008
    • 435
    and all it takes is a leakey $4.00 transfer case output seal to make it all worthless...
    '72 S3 88 - Leakey & Squeaky
    • JackIIA
      • Dec 2008
      • 498
      i was thinking the same thing!
      1970 88 IIA
      • TJR
        • 279
        The same oil has also kept all the parts well preserved..
        • daveb
          • 513
          I have to admit that I have yet to have a handbrake fail due to oil soakage. There is still enough surface area there that combined with the multiplication through the differential, there is plenty of holding power.
          If your handbrake won't hold the vehicle, it is simply not adjusted correctly.
          • I Leak Oil
            • 1796
            For the most part series trucks are just so simple. But why all that linkage and hardware when a simple cable would have sufficed? Could never figure that out.
            • daveb
              • 513
              Clearly due to the power and influence of the Linkage Guild.
              • I Leak Oil
                • 1796
                Ah yes, you are right. It's the same guild that had their dirty hands in the throttle and hand throttle linkage debacle of the late 40's. It's all so clear now.
                  I think it goes back to a time when things were manufactured to last more than 5 years. Or...maybe I'm cynical because the clutch cable just snapped on my piece-of-junk backup car that I didn't want to have to spend any money on.
                  • cgalpin
                    • May 2010
                    • 74
                    Yup the IIA is very similar. Here are pictures of mine cleaned up
