Is the throwout bearing on the Series 3 clutch arrangement supposed to contact the pressure plate fingers at all times (even with the clutch fully engaged)? If so, how is the preload of the TO bearing against the pressure plate fingers controlled?
If there is supposed to be a gap between the TO bearing and the pressure plate, how is it adjusted? It seems that there is no adjustment, and there is a spring internal to the slave cylinder that is always trying to push the TO bearing against the pressure plate.
I'm trouble-shooting a faint chirping noise that occurs with the clutch fully engaged. As soon as I move the clutch pedal enough to put a tiny preload on the TO bearing, the noise immediately goes away.
This may be covered in the factory manual, but I haven't had a chance to check yet.
