re-arching the springs, shock questions
  • glbft1
    • 149
    hello all,
    Going to have my military springs re-arched and apply the tape from terri-anns site, the question is should I upgrade the shocks to pro-comp( more modern) or just go with new heavy duty standard replacement ones??
    thanks
    greg
  • NickDawson
    • Apr 2009
    • 707
    the pro-comps changed my ride substantially, for the better.
    • chester rides again
      • Aug 2007
      • 116
      I was so amazed at my spring and shock upgrade. I went with the Rocky Mountain parabloic springs and OME shocks. The change was amazing!
      '68 109 3 door with multiple personalities
      '03 Ford Excursion 7.3 diesel
      '07 Porsche Carrera S Cabriolet
      • Jim-ME
        • 1379
        Unless they have improved greatly since my son had them on his Jeep my vote is for OMEs.
        Jim
        • msggunny
          • Jan 2007
          • 621
          OME and parabolic springs.
          04 DII
          08 D3 (LR3)
          • bmohan55
            • Sep 2008
            • 435
            When I went with new genuine LR springs in the rear (from our hosts) I also went with the standard oil filled shocks. Acording to them and others I spoke with the standard spring (non-parabolic) doesn't require a more active shock due to it's greater stiffness. You may be spending more than you need with the gas...mine is riding great (for a Series..the way it was ment to be) with the standard set-up.
            '72 S3 88 - Leakey & Squeaky
