I recently had the truck in the garage to top up the gear box - the seal between that and the transfer box has failed, resulting in excess gear oil in the transfer box. Some at our host suggested just keeping both filled properly to avoid problems until I got around to tearing everything out.
I went to pull the truck out, put the clutch in and it went right to the floor with no resistance. I tried to put it in gear, but wasn't able to do anything but grind the gears. I gave up and went outside and mowed the yard.
I noticed that last week I was hearing the gears grinding a bit more than normal when I shifted, I just figured I was rushing thing and made a mental note to shift slower.
Looking at the green bible, it looks like I've got to tear some stuff out, but just wanted to find out if I might be lucky enough to have a much simpler fix.
Any help would be great.
