Replacement part or ideas
  • crankin
    • Jul 2008
    • 696
    I am switching over to a liftgate and I am looking for the Upper hinge brackets. It appears that the RH one is no longer made (P#: RNB843/ LR#334068). Does anyone know of any laying around, recreated something that works, workarounds, etc..?
    Also, how do these hinges attach to the roof itself? I can see that it looks like the two holes are pop riveted into the door frame opeing. But what about the top part?
    Thanks.
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
  • Jim-ME
    • 1379
    I have a set of the brackets for sale. Send me a PM if interested.
    Jim
    • cgalpin
      • May 2010
      • 74
      The top is pop riveted too. If you need a picture I can take one of mine. I also have a set of these brackets if needed.
      • crankin
        • Jul 2008
        • 696
        Do you mine taking a pic? That would be great!
        • cgalpin
          • May 2010
          • 74
          Certainly. I took a picture of each side (sorry the second is a bit blurry) and one shot from the outside showing the top rivets.
          • crankin
            • Jul 2008
            • 696
            I am just excited to use the rivet gun again! Was this from factory or did you add this on later?
            The only reason why I ask is that I noticed the rest of the rivets are painted. I think that its wild the order that land rover assembled these things.
            • cgalpin
              • May 2010
              • 74
              I wondered the same thing. My truck is new to me so I honestly have no idea. I keep forgetting to do it, but I plan to get a heritage certificate which might answer questions like this (if it came with a liftgate or not).
              It might just be that they made the base roofs and painted them, then added things like these brackets if the vehicle had a liftgate instead of a SW rear door for example but I am not sure.
              Anyway, I hope the pictures helped.
