Looking for pics of Tuffy console between seats
  • TJR
    • 279
    I'm Looking for pics of Tuffy console between the two front seats (series trucks) ... Does it fill the void pretty well? I like the OE bench seat look, but will never use the middle seats? I think the Tuffy cubby woul dmake more sense? Opinions? Talbot
  • bkreutz
    • Apr 2010
    • 408
    Does this help? I just finished mounting mine, don't have pictures of it with the seat bases installed, but can do that tomorrow if you wish. I also diverged from the mounting instructions a bit to make it work better with mine. I thought it was going to be too tall, but once in, it's about the perfect height for my right arm to rest on. Fills the space between the seats completely. I did have to modify my overdrive shifter to use the cupholder. (put a dogleg bend in the shaft)
    Gale Breitkreutz
    '03 Disco
    '47 CJ2A
    • galen216
      • 236
      I don't have a pic but the tuffy is a perfect fit. There is about enough space between the seat and box to put a map book or something like that.
      It increases your storage space by quite a bit and gives you something to rest on. I love mine and wouldn't trade it. It's a great upgrade/addition.
      I mounted mine to the tunnel cover so I can easily pull the whole unit out and check trans/od levels.
      74 SIII
      96 Disco SE-7 5 Spd.
      • daveb
        • 513
        Hey i like this thread. I am looking for some spare change for the toll that is coming up. But all I found was a couple dried up french fries.
        Originally posted by TJR
        I'm Looking for pics of Tuffy console between the two front seat...
        • scott
          • 1226
          it took a second, thanks
          '64 Series IIA 88 Canvas Tilt
          '68 Series IIA RHD Ambulance
          '76 Spitfire 1500
          • LaneRover
            • 1743
            but were the fries still good?
            • daveb
              • 513
              Probably, if you can get all the sand, MAR dirt and carpet fuzz off them. I just left em down there.
              Seriously, love the tuffy boxes and look for them on ebay from time to time.
              Have found two used ones in good shape for around $180.
              Definitely get the one with the radio compartment. I like Galen's approach of being able to remove it, but in my 'hood I decided it was better to bolt it down. besides, there are wires coming through it and I don't have an overdrive. But that's just me.
              Been waiting to put one in the 90...stereo at the moment is giving me fits in its present installation. So perhaps it's a good time to do it.
              Trouble is that my speakers are in the center cubby and I don't want to cut holes in my tuffy. So where to put the speakers is a question.
              • scott
                • 1226
                .. So where to put the speakers is a question.
                i posted a pic of my speaker placement once but one of you guys made fun of it and made me cry. they're round and hanging in a cargo net strung from the hoop set. the meanie said it looked like breasties in a fishnet brazier. they do but it works and i can almost hear 'em over the rover rattling, engine whinning and wind whistling
                '76 Spitfire 1500
                • galen216
                  • 236
                  My middle panel has the lock hinge on it so if I really needed to I could put a padlock on it.
                  My tuffy was in the truck when I bought it. I'm too cheap to buy, made the one in my last truck
                  I like fries.
                  74 SIII
                  • greenmeanie
                    • 1358
                    I like fries.
                    I originally attached my tuffy to the center inspection panel but keep looking at it and thinking that it is a heavy bit of steel and when I roll over I have to think that I don't want to be sharing the cab with it. After 10s of thousands of miles with it that way I am finally gettign round to mounting it more securely with 4 screws to the seat mounts.
                    • galen216
                      • 236
                      My inspection panel has a lip at the back and the hinge in the front. It can't let loose in a roll over. When I bought the truck it was just sitting in there and that was not a good solution.
                      74 SIII
                      • greenmeanie
                        • 1358
                        Mine has that lip too. It is thin aluminium and it will bend and let the cubby lose in a roll. Don't ask how I learned that one.
                        • bkreutz
                          • Apr 2010
                          • 408
                          Here's a couple of pics of what mine looks like now. The first pic is of the inspection panel, I removed the hasp from the front of the panel (it interfered with the console sitting flat) and then made a rear mount out of 1" square tubing, the front is 1/4" bar stock. I drilled and tapped them so I could bolt them to the panel from underneath, then drilled and tapped 3 more holes in the top to line up with the holes in the console. I screwed the panel down to the seat box, but they are underneath the console when installed so the console has to be removed before the panel can be taken off. I ran the wires underneath the Rover to the center where the radio cutout is. Second pic is the console in place, still have to make a overdrive boot. (didn't like the Bronco transfer boot that the PO had on it.)
                          Gale Breitkreutz
                          '03 Disco
                          '47 CJ2A
                          • kevkon
                            • Aug 2009
                            • 364
                            Here's my custom cubby;
                            [IMG] [/IMG]
                            I wanted more clear room at the front and didn't need to mount a radio.
                            94 D-90 tdi
                            72 Series III
                            • mrdoiron
                              • Dec 2009
                              • 446
                              here are couple I have that partially show the tuffy I installed:
                              1961 Ser IIa Hybrid Defender
                              1969 Ser IIa Bugeye
                              1998 Disco - ex wife :-(
                              2010 RR Sport Supercharged
