Third Brake Light
  • amcordo
    • Jun 2009
    • 740
    Third Brake Light
    Anyone figure out a third brake light setup that looks OK?
  • bobzinak
    • Apr 2009
    • 91
    look at the hella "3106 series" led stoplight bars from HELLA. they surface mount so you could stick it above the back door. draw very little current. come with a really long wiring. simple to install. no need for worrying about if the rover wiring would handle it. simple, clean.. bobzinak.
    • mongoswede
      • May 2010
      • 757
      There are quite a few LED brake strips on the market these days that can be mounted almost anywhere and are hardly noticeable until they turn on. This might be a good way to get some extra brake light attention...there is the added benefit that LED's last a long time (longer then your rover probably) and draw minimal amounts of current.
      • crankin
        • Jul 2008
        • 696
        Forgot about ole Nick from over the pond...
        Birmabright Brotherhood
        Clint Rankin - 1972 SIII SWB
        • kevkon
          • Aug 2009
          • 364
          It might be more useful on a Series to have a Accelerator Light That probably being what catches more people by surprise.
          94 D-90 tdi
          72 Series III
          • jgkmmoore
            • Sep 2008
            • 105
            Cool! Never thought of accelerator light!
            So I made one today out of an old mercury switch. Tested it in the Suburban first, and it worked fine. Then moved it to my 109 Trop SW with a mature 2.25 petrol. Couldn't activate it, even on a steep uphill slope. Strange, because 'shotgun' riders have always been inordinately frightened by the 109....and I assumed it was the sheer speed and hard acceleration that would distort their jowls.
            So....took a neighbor for a short ride. Watched him closely, and discovered the jowl distortion was caused by scowling. Hmmmmm......
            0-60 time: not recorded. Flat road, no tailwind...never made it. 58.9 in 4 min 11 sec.
            Regards-Jeff
            • kevkon
              • Aug 2009
              • 364
              Your mistake was choosing a mecury switch. For a Series something like a hour glass would be better to respond to the abrupt change in speed.
              94 D-90 tdi
              72 Series III
