Any issues with towing an SIII 88" using one of those trailers where the front wheels are off the ground? Thanks
Towing a Series III
Towing a Series III
sigpic
Nate B
88 D90 RHD, V8 Present
80 Merc 230GE Petrol in 2011
92 Range Rover - In the 90's
cuis2000@yahoo.comTags: None -
no experience with towing rovers on a dolly..
but plenty with early CJ jeeps..
I have always pulled the rear driveshaft.. as long as the bearings are good on the axle the vehicle will tow just fine..
problems happen when the driveshaft is left in place and drive trains aren’t put completely in neutral, or there is poor lubrication in the gearbox because the engine is not turning it.
I have also had problems with vehicles with automatic front lockers and non manual hubs..
for the time it takes.. disco the rear shaft and you don’t have to worry about anything.1971 SIIa 88" NAS Dauntles V6
1974 SIII 109" RHD -
If it's an option rent the full trailer from U-haul. I brought me IIa home with one and it was only $98 (one way rental, 2 days allowed).64 IIa 88
94 Discovery
06 Toyota 4R (DD)
~Matt
"Not all who wander are lost"~TolkeinComment
I've flat towed and used a trailer. Personally I wouldn't use a dolly unless I removed the rear driveshaft. It's the only way I wouldn't worry the whole time I was towing. Really you only need remove the driveshaft at the diff and hang it in in the frame but total removal is a better piece of mind.74 SIII
96 Disco SE-7 5 Spd.Comment
What if you put the rear on the dolly and front on the road? Are the risks less?sigpic
Nate B
cuis2000@yahoo.comComment
I towed my series behind my discovery using a dolly for about 400 miles round trip and it was fine. Well, I take that back, the tire fell off the series at one part.... make sure to tighten those lug nuts real well!!!!2001 Discovery II (featuring CDL)
1974 Series III 88"Comment
When everything works dollys are great... better fuel economy and you can travel a bit faster if you have a heavy vehicle (brakes)
all you need it to hit one bump and something in the cab knocks a lever, or something jiggles the wrong way and POW.. drivetrain all over the HWY...
you can tow vehicles backwards on dollys as long as there is a good column lock and you run the seat belt through the steering wheel to act as a brace..
but this should only be done is the rear wheels are inoperable.
Everything mentioned above I have had personal experience with...
Do yourself a favor and pull the shaft at the pumpkin and bungee cord it to the chassis out of the way.. you wont have to think about anything but the drive.1971 SIIa 88" NAS Dauntles V6
1974 SIII 109" RHDComment
I towed my 109 soft top 1000 miles with my grand cherokee V8 on a U haul dolly. In a snow storm from nantucket ma, to louisville ky and had some hills to deal with. Got about 8 miles per gallon and never went over 60 so that was lame but all in all it wasn't that bad. I put the front on the dolly and removed the rear axle shafts and put the flanges back on and away I went. the truck was loaded with random parts too so had some extra weight. My advice is make sure your towing rig has some nice fresh brakes.1970 Series IIA 109 EX-MOD
1971 Series IIA 109 EX-MOD
1982 Mercedes 300TD
1989 RRC
1993 D110
1994 RRC LWB
1995 RRC LWB
1995 RRC LWB
1995 Disco
1996 GMC 2500 Suburban
1996 Disco
1997 Disco
2001 RR P38
2005 LR3 HSE
2006 RR HSEComment
flat towed an 88 w/ a lr3 over 800 mi, no problems. 88 in 4th, transfer case in nuetral and front hubs unlocked. got up to some stupid speeds too'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
