I saw a set of 215/85/16 tire's the other day and thought they would look good on the Series 3. Anyone ever use this size befor?
another tire ?
I have them on my 66 IIa. I'm away from my computer, but will try and post picks in a few days. I think they look great ona series rig. They are tall, but skinny, which allows for easier steering, and a very traditional series look.Bad gas mileage gets you to some of the greatest places on earth.Comment
ORIGINAL 750x16's:
With 235 85 R16s / NATO steel wheels on the same Rover (6 years later). Don't know if the rim offset is different, but it is certainly wider to accomodate the wider tire correctly:
I use my truck for exactly the same purpose Yank, I do have an overdrive, and a fresh engine, the highway speeds are about as good as you could expect with a series. My experience is that wide tires float in mud, where a narrower tire will dig better to find the solid base better. I guess I can't air down to get as wide a footprint as a 235, but I'll take it, as ir steers much better with the 215s.Bad gas mileage gets you to some of the greatest places on earth.Comment
FWIW.....
My 86 Ford dually runs the 215/85 (stock) which are far LESS popular than the 235's. If you concerned about availability, the 235's are out there in great numbers, the 215's...not so much.64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
