I have a pretty substantial radiator fluid leak coming from under the water pump assembly. The fluid appears to be leaking from hole in the bottom side of the housing for the spindle and bearing for the radiator fan (opposite the set screw in the top of the housing). The leak stops when the engine is shut off and the coolant cools down.
Any ideas? Am I missing a plug for this hole?
