My 1969 has a heater and the blower does not work. I tested and cleaned the switch in the dash and checked voltage. It is seeing 10.5V after and before the switch. I am seeing the same voltage at the blower motor wire disconnect. Am I correct in assuming that the motor is shot? If so, what is the easiest way to replace the blower motor without removing the heat exchange unit or disconnecting the hoses from that unit? Is there a way - wing removal possibly?
BTW - the heating hoses do heat up great when I manually switch the heater water hoses to open flow.
Transmission - I asked this in a previous post but it may have gotten lost among other stuff. The yellow 4 wheel drive selector is floppy and needs to be held up with a rubber strap. Any idea if this is something I need to deal with right away or can the vehicle be driven before I get this looked at? I am driving in HIGH since I am using the vehicle for normal driving conditions.
Thanks a bunch
Harry
Thanks a bunch
Harry
