Singapore Defenders Anyone?
1961 Ser IIa Hybrid Defender
1969 Ser IIa Bugeye
1998 Disco - ex wife :-(
2010 RR Sport Supercharged
http://mikerovers.shutterfly.com/ -
Buddy HS Lim just talked with him...Since I would need to max the use on athe container already being paid for, would make sense to max that shipment, and apparently 3 can fit in one container.
I guess if I put 3 individuals names, one for each vehicle I should be ok.---------------------------
1969 Ser IIa Bugeye
http://mikerovers.shutterfly.com/Comment
He gave me 5 "engine chassis numbers " as below, but not sure how to translate those to VIN or yr of mfg, as they need to by >25yr old to import...
1. E 18J 00030; C233565
2. E 18J00528; C226574
3. E 18J 00375; C231058
4. E 18J 00633; C233741
Anyone have an idea how to get the DNA on these ?
1969 Ser IIa Bugeye
Any chance someone knows how to interpret these "engine chassis #'s" to something understandable - then get the year of mfg?He gave me 5 "engine chassis numbers " as below, but not sure how to translate those to VIN or yr of mfg, as they need to by >25yr old to import...
It is possible what he provided are some military only number??
thx---------------------------
1969 Ser IIa Bugeye
18j may be diesel engine code and I assume the engine serial #. 19j was the 2.5l Turbo diesel IIRC.
you need the VIN like this;
SALLDHAC7BA225082
SAL Manufacturer code: Land Rover
LD Model: Defender (for early models: Ninety, or One Ten)
H Wheel base: 110 inch
A Body type: 2-door: Pickup, hood cab, truck cab, or soft/hard top
C Engine type: 2.5 litre diesel (model 12J)
7 Steering and transmission: Right-hand drive (RHD), 5-speed manual (LT85, LT77, LT77S, R380 or other)
B Model year: 1985 to 1987
A Assembly location: Solihull, UK
225082 Serial number
then plug it in here:
The Clifton website provides info on scientific text services, about the Linux BogoMips mini-Howto, off-roading in a Land Rover Discovery, and Arabic calligraphy on oriental rugs
the 6 digit code with the c prefix MAY be the last 6 numbers of the VIN:
SALLDHAC7BA233565Comment
thanks, you may be right... still cannot determine if there is a reference chart to help decode somewhere, came up blank online search.18j may be diesel engine code and I assume the engine serial #. 19j was the 2.5l Turbo diesel IIRC.
http://forums.lr4x4.com/index.php?showtopic=19726---------------------------
1969 Ser IIa Bugeye
I suspect 18j's might be 24v 12j diesels. it is only a guess though. Defenders of that vintage should have 12j engines.
[edit] I think the E in the info you were given indicates the engine model# and serial## and I am willing to bet the C for the second # = "chassis" , in other words it was just shorthand from the seller, ex:
1. E(ngine) 18J 00030; C(hassis) 233565
2. E 18J 00528; C 226574
3. E 18J 00375; C 231058
4. E 18J 00633; C 233741
You need to ask for the "SALLDHAC7BA" part.Comment
Great DNA breakdown, this makes sense. I will request the first 11 digits also... my sense is since it is a lot of vehicles this is all he had at the time...I suspect 18j's might be 24v 12j diesels. it is only a guess though. Defenders of that vintage should have 12j engines.
thanks---------------------------
1969 Ser IIa Bugeye
I imagine they didn't bother giving you the initial portion of the VIN because, if these vehicles were all bought as one contract, those initial 11 digits would be identical amongst all the 110s purchased.Comment
The VINS I now have,
They do all start the same, as SALLDHAC7BA+chassis s/n's.
From this it seems they are 1985-87 vintage, and no apparent guarantee on being 25yrs or older... as they could be 87... any other way anyone knows of the age with only VIN and no other docs. I think there will be a problem importing if the VIN doesn't clearly indicate 25yrs, like if the 10th character was an A rather than a B.
??Last edited by mrdoiron; 10-05-2010, 04:19 PM.---------------------------
1969 Ser IIa Bugeye
If this vast, pool of Land Rover knowledge cannot positively determine what year those things are, how is customs going to do it? I am serious. What method do they use in determining this? I would be surprised if it were a good method.
Although, I bet with the kind of power they wield, it doesn't really matter huh?
"I can't believe I'm sitting here, completely surrounded by no beer!" -OnslowComment
The way I break that VIN is model year 1981, A is 1980 but the 17 digit VIN came into use in 81, then went up 1 letter each year (but skipped the "I" because of possible confusion with the numeral "1") the first part with all the letters indicates country of origin, manufacturer, model, assembly plant, etc. I'd have to find one of my old books to get the exact breakout. I do remember that the "S" was England and "AL" is Land Rover. (another example is WVW which is a German made VW as opposed to 1VW which is a US made VW)Gale Breitkreutz
'03 Disco
'47 CJ2AComment
