This is a follow up post from points to pertronix. In the course of making that switch I have discovered the following so to keep the 2 issues separate I thought I'd start this new thread, I should say that I haven't had a chance to even look into the issue yet I just didn't want to confuse the other thread with this issue.
The throttle shaft on my carb is worn, which if I understand things correctly means that air can get into the carb thus making it run lean which could be a contributing factor to the popping sound I get from the exhaust when I back off the gas. It seems my choices are as follows.
1. Get the throttle shaft on the carb rebuilt. Trevor (the automotive teacher, at the community college where I work) recommended having this done by a professional as it requires some fairly skilled work to get new bushings put in place etc.
2. Get a new carb.
So I'm off to explore those options, cost etc.
Carb is a Zenith. (Has 36 IV on it too)
If anyone has thoughts, experience, questions, advice etc please let me know.
Thanks, Steve..
1975 Series III 109 FFR reduced to 12V. 2.25L engine.
2. Get a new carb.
Thanks, Steve..
