Moulded Matting System
  • rejeep
    • Apr 2010
    • 420
    any first hand experience with this system?
    Looking to address the floors in my truck..
    Anybody have an good advise on perhaps another product if not this?
    1971 SIIa 88" NAS Dauntles V6
    1974 SIII 109" RHD
    What's wrong with your floors?
    • rejeep
      • Apr 2010
      • 420
      nothing in need of repair..
      just looking to throw a bit of sound and heat deadening on the floor..
      Ive seen the regular rubber floor mats, and I saw this option..
      from the lack of response I feel the price tag has priced it out of many peoples budget..
      1974 SIII 109" RHD
      • LaneRover
        • 1743
        Speak loudly but succinctly - don't forget to enunciate.
        I have used cut down truck mudflaps for all sorts of stuff - including the footwells/floors.
        • thixon
          • 909
          the people who have shucked out the bucks for this seem to like it. As far as the heat thing goes, it probably won't help that much, since it doesnt cover the tops of the footboxes or the center portion of the bulkhead. It does look cool, and is supposedly well made.
          You could probably make something cheaper on your own using horse stall matting, mud flaps as suggested, or an number of other products.
          Travis
          '66 IIa 88
          • mrdoiron
            • Dec 2009
            • 446
            If sound deadening is a goal, use some Dynamat, then cover with what ever look of floor covering you wish. Is a great product to deaden the tinny rattle, especially if adding a stereo, apply to inside of doors before adding door panels, and makes a big difference.
            mike
            1961 Ser IIa Hybrid Defender
            1969 Ser IIa Bugeye
            1998 Disco - ex wife :-(
            2010 RR Sport Supercharged
            http://mikerovers.shutterfly.com/
            • HinFL
              • Apr 2010
              • 28
              Exmoor Trim Insulated Floor Mats
              I just installed the Exmoor Trim insulated floor mats, front and rear, in my "new" 1973 Series III 88. I purchased them from our host. They look good and reduce noise and heat to some extent. I considered the moulded matting system, but must admit that the pricetag got my attention! Hope whatever route you take helps your situation.
              1973 Series III 88"
              sigpic Pretty good performance from the old 2.25 petrol! Then again, she does have the Fairey overdrive...
              • rejeep
                • Apr 2010
                • 420
                I bit the bullet..
                once I recieve it I will post up some pics
                1974 SIII 109" RHD
                • amcordo
                  • Jun 2009
                  • 740
                  My kind of answer.
                  • crankin
                    • Jul 2008
                    • 696
                    I installed the molded system in my rig. It cuts down on the heat greatly. I am not so sure about the sound deadening of it. Its still loud in there. However, i think its quieter when i drive around with my roof off. Something makes me think that with the roof on all the sound has no where to go except in my ears.
                    Its HEAVY and thick! You can install it with the seat box in place...but its much easier to remove the seat box and make all the cuttings and attach seat rails and e-brake boot. I had to go to fastenal and get longer seat rail screws.
                    I had to trim the piece that goes around the gas pedal bracket and cut all the seat rail bolt holes, also had to cut the box openings out. I did only cut three sides, so that I could flip the one section up to access the fuel tank.
                    It does offer a cleaner, neater look truck IMO. A clean up is easy...just spray out with a hose and use a brush to get dirt up.
                    I have also installed dynomat with dynoliner on the roof and door panels. I didn't install it on the floors...but i am considering it.
                    But all in all...you will always have a loud truck.
                    Birmabright Brotherhood
                    Clint Rankin - 1972 SIII SWB
