AC Delco alternator install on 3MB engine
  • Tim Smith
    • 1504
    Anyone have pictures of an AC Delco alternator on a 3 main bearing 2.25? I was originally hoping to keep this down low near the original location but seeing the mud that killed mine, I think moving it up higher will be a better idea.
    I'd like to see some pictures of other installs to get some ideas.
    Cheers!
  • Leslie
    • 613
    I have a photo somewhere, but I don't know where it is at the moment (currently at the beach). Mine is in the stock location, w/o any special mount: what I had to do was flip it to swap the pivots, in order to get the pulleys to align.
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    • msggunny
      • 621
      I have one here somewhere using Ike's mount. I don't have access to a computer, doing this off my blackberry otherwise I would link it to this.
      Check the "what did u do to your rover today" thread or you can wait until I can get you one later this week.
      04 DII
      08 D3 (LR3)
      • KevinNY
        • 484
        Here ya go. On a 5MB if that makes a difference.
        • Tim Smith
          • 1504
          Thanks Kevin, and everyone else.
          I'm going to try for the stock location just for now. I have a 2.5 which had a raised mount (much different that Kevin's). Turns out the timing cover is very different between that engine and the 3mb I'm working on.
          The one that Kevin shows looks like the Pangolin mount which by the looks of it, would work on either engine. Very nice. I may go for something like that in the end.
          • gudjeon
            • 613
            I mounted mine low in stock position:
            From below:
            From above:
            I used the stock ear in the cast and made a long, stepped throughbolt to make the pivot/clamping mount and machined a piece of round stock to take up the extra space. The ear of the alternator wash ground/files yo make it line up with the pulley. The adjustable bracket was welded onto a piece of flat bar and was one from a donor car that the alt came from. I fit this snug little mod into my 2.25 fueled ser1. The belt is for a power steering pump from a '98 Neon. Line it up good and it lasts forever.
            • Tim Smith
              • 1504
              That is pretty much what I am putting together gudjeon. Thanks!
              Do you happen to know what alternator that is you have? I picked up one for an 85 camaro and it's all the same but the pulley. Unfortunately, I'll have to bore out an old pulley to make it work unless I could just swap it for an alternator that already had the same set up.
              • gudjeon
                • 613
                I know it was out of a 1986 Chevette. About the only good thing from one of those. I think its the 10si? The higher output alternator has the molded fan, not the stamp finned one. This is just the pulley that came with it. I love these old goodies. Get them out of the scrap bin for $0, put in a $35 kit, some cleaning and paint, and your set.
                • TJR
                  • 279
                  Kevin. is that a P/S pump and P/S gearbox in your pic?
                  • jac04
                    • 1884
                    Here is a Delco 10SI mounted using the Pangolin brackets. The alternator I ended up using was a completely new unit (not rebuilt) from NAPA. IIRC, it came with a lifetime warranty:
                    • Tim Smith
                      • 1504
                      Very nice as usual. Can you give me a belt number off of your set up?
                      • jac04
                        • 1884
                        ^^ The belt is a Dayco TopCog 15495.
                        The alternator is a NAPA 1N-4011A. This is a single groove pulley alternator that I swapped to the double groove using a pulley that I already had. You should be able to get a double groove pulley version as well, but I don't know the part number.
                        • KevinNY
                          • 484
                          Yes it is. In fact I still have the pump and bracket if someone were to want to do a PS conversion. It requires the double pulley fan.
                          • mongoswede
                            • May 2010
                            • 757
                            is that a Scout/Bronco Pump?
                            • Tim Smith
                              • 1504
                              Excellent. Thank you.
