My rear pinon seal gave way a few weeks back, and I replaced it, but the new one leaked right away. I took it apart, and sure enough the seal was damaged. I am guessing I put it in there incorrectly or something? Well, I replaced it a second time, and that one too started leaking almost right away, although not as severe.
The first attempt, I tried to sort of tap the new seal in there, and the second attempt I put the seal on the retainer and allowed it to push it in as I tightened the castle nut. I haven't taken the 2nd one off yet, but I am pretty sure it will show damage as well.
Is it just a case of me tightening these things down too much? I tried to go a little easier the 2nd time around, but perhaps I still over tightened. I don't have a torque wrench.
uzzled:
); the pinion is about half way up the diff, so it will only leak until about half-empty (or half-full) rather than leaking until all-the-way empty like it will if it leaks at the drain plug.
