A fe Questions
Thanks TriedStone!
Any info on the oil? I know its a dumb question, but this is my first Rover and my first 4X4. So, is the oil its leaking coming from the rear differential and I just need to make sure its full of the righ oil? Or, is there a place to put oil in the hubs and if so, what oil does it take?
Thanks!
JComment
Having fought with my rear hub seal a couple of times, I actually would opt for the paper gasket. I tried sealing mine twice with silicone based sealants, and it still leaked. I must not have had something right.
The oil is the differential oil, EP90 or some other variant of the same, that you are losing. Just jack up the axel really high before you undo the hub, and you will get minimal leakage when you crack the hub seal apart. Top up the diferential when you are done.
Or, you could drain the diff prior to starting the project, if you plan on replenishing the rear with all fresh oil.Bad gas mileage gets you to some of the greatest places on earth.Comment
It's hard to tell but I think I can see a loose bolt on your flange. Looking at where the oil is coming out from, it definitely looks like majority of oil is coming out the flange seal.
You might get lucky and find out the flange is just loose. Give that a try while you are waiting for the parts to arrive.Comment
Also, the wheel nuts look to be turned around... the bevel piece fits very nice against the wheel.
Birmabright Brotherhood
'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
Using sealants can be somewhat tricky. The key is getting one that's compatible to oil and grease. Some of the RTV (room temperature vulcanizing) sealers can be dissolved by oil. "Right Stuff" works well, Toyota has some stuff they call FIPG (form in place gasket) that works super, I found out about it when I worked at a Lexus dealer (I've since retired from the trade, 43 years was enough
) it's a bit pricier then most of the other brands, but it's the best I've ever used.
Gale Breitkreutz
'03 Disco
'47 CJ2AComment
As many others have said, the CD has some challenges.
For me, it was totally unusable - wanted an older version of Acrobat or something - tried on many different computers, and I'm no slouch in the nerd department. Couldn't get it to work. Its a coaster for beer now.Comment
There is a guy in Ashby Mass. Who is selling a used Green Bible right now on Land Rover exchange. Some other parts included. If you contact him, he may be willing to separate out the books. I won't post the other stuff he is selling out of respect for our hosts, Here is his info though.
__________________________________________________ __________________________________________________ __________________________________________________ _
...... Factory repair manual used,........ Will sell as a lot $80.00 or individually
Kevin-Scott Crawford.
Ashby, Massachusetts, United States of America - 29 May 2010
e-mail: gumabby@yahoo.ieBad gas mileage gets you to some of the greatest places on earth.Comment
