Hey folks,
Just installed a new booster from our hosts. My old one was bad in that when you depressed the pedal it leaked air, the vacuum would drop a little...
This one is just hissing non stop and the in-dash vacuum gauge dropped way low. If I pull the hose off and plug it with my finger, the engine smooths out and everything is fine.
It doesnt appear that the air leak is at the hose or the 90 degree valve - although the 90 degree valve is quite lose and comes out with a good tug. It is coated in grease and seems to make a good seal when re-fitted.
So, is there some part of the install that the green bible doesnt cover that I should know? Do I need some kind of gasket somewhere, is there some kind of priming that has to occur or is this thing just leaking air like a sieve because its faulty?
