Engine trouble
  • PH4
    • 375
    #16
    I have now come to the conclusion it is most likely a carb issue. Running fine and hit same original bump as the one a few weeks ago and it shut off. Coast to side and will not crank and run unless choke pulled out. Drive with choke out for awhile and then will run with choke in interminttingly. Maybe float getting stuck after large bump? Bump is on bridge going off the island so no way to miss it. Plan to take off carb (Weber) and soak in carb cleaner.
    • kevkon
      • Aug 2009
      • 364
      #17
      What isn't a bump with a Series?
      94 D-90 tdi
      72 Series III
      • bkreutz
        • Apr 2010
        • 408
        #18
        Parked
        Gale Breitkreutz
        '03 Disco
        '47 CJ2A
        • kevkon
          • Aug 2009
          • 364
          #19
          Only if your not sitting in it
          94 D-90 tdi
          72 Series III
