Rocker arm bushing replacment on 2.25L Petrol
Has anyone sucessfully changed out their 2.25L petrol rocker arm bushing? I'm about to embark on this task and was looking for any pointers.
One thing I have noticed is that the replacment bushings in free state (i.e not installed ) already fit tight on the new rocker shaft. The shaft is .530" OD. After presing the bushings into the rocker armss, it's only going to make them tighter. Therefore I assume it just must be 100% required to hone or ream the ID of the bushings to size?
Any comments or techniques you've used w/ sucsess? Thanks Talbot
There was far more wear on the rocker shaft than I expected. It needs to be replaced! The springs look a bit thin too (on the ends of a few).
