Rims for tubeless tires?
  • PH4
    • 375
    I have always run tubed tires on my 109s. Is there any problem with running tubeless tires on my stock series rims/wheels?
  • feildpickedrover
    • Jun 2010
    • 34
    I was curious about this too, I was told tubeless tires can be run on rims meant for tubes, but there's no safety bead on the tubed rims, im assuming that its not recommended because if you get a flat there's nothing holding the tire on? also the bead helps the tire seat with a good seal, so im thinking it might cause leaks, ill probably be proven wrong on al least one of these things, but i thought i would try helping for once Id also like to see if anyones tried it though because ive got the origional 16s mor my 88 id like to use
    field picked 1965 series 2a 88"
    sigpic
    • Lalo88DK
      • Nov 2009
      • 116
      I have been running without tubes on standard riveted rims for years and now on 1-ton riveted rims, with no problems what so ever, I know quite a few guys doing the same. The reason for me taking out the tubes is simple, I got more punctures with the tubes (no foreign objects, probably poor quality tubes although brand new) in tubeless tires. The reason according to a tire-specialist is that the tube is rubbing against the small lines on the inside of the tubeless tire, and since it's nearly impossible to get hold of tubed tires nowadays, he recommended to loose the tubes.
      You can have problems though, if you let out a lot of air and run tubeless on tubed rims, because of the missing safety bead, but I have never experienced any problems.
      • jac04
        • 1884
        Do you have welded or riveted wheels? Welded wheels are usually for tubeless tires, while riveted are for tubed.
        • yorker
          • 1635
          A lot of people run the original rims tubeless- the rivets usually hold air and if they don't you can paint them, galvanize them, or put bead seal on them, then install a tr-15 valve stem fort the 5/8" hole. They lack the safety bead bump but so do some other "tubeless" rims. IIRC American 16.5s often lack safety bead bumps.
          Professional-grade landscape tools, supplies, and safety for crews. Gemplers is a small, family-owned business based in Wisconsin and serving outdoor professionals across the U.S.A. since 1939.
          Land Rover UK Forums
          • gudjeon
            • 613
            On the other side of the pond, running without tubes is frowned upon.
            In short, running without tubes is less problematic. New truck radials are not smooth on the inside and with generate a lot of heat and make this type of failure likely. Tubeless punctures are easily dealt with in the field with a cheap repair kit and compressor. As for the safety bead, I have seen tires fly off with them so I am not convinced of that argument. I have 1957 rivetted rims holding air with no problems. I put some sealant on the inside as an extra insurance. I have seen 90's era GMC heavy truck rims with rivetted construction, so I am not buying that argument either.
            • RoverForm
              • Jul 2010
              • 348
              can someone please explain the reaction in this video?
              • JimCT
                • 518
                Seating the tire bead
                the easiest way to seat the tire bead is with ether, and a match.
                1963 Unimog Radio box
                1995 LWB RR
                • RoverForm
                  • Jul 2010
                  • 348
                  so you spray some ether on and around the bead, then light it? does the flame cause the ether to suck in air? because in the video it looks like the tire inflates also...
                  • bkreutz
                    • Apr 2010
                    • 408
                    When you light the ether (lighter fluid works too) it expands rapidly seating the tire (and inflates it too). This is the "I don't have a compressor" method. (works quite well though)
                    Gale Breitkreutz
                    '03 Disco
                    '47 CJ2A
