2.25 Question
  • usadventureracing
    • Sep 2008
    • 106
    2.25 Question
    I was wondering if anyone can help me. My IIa stalls when I stop at lights or stop signs.
    So far I replaced;
    plugs
    condenser
    fuel pump
    fuel filter
    I rebuilt the carb and set the points and timing.
    I was wondering if it could be a vacuum leak?
    Thanks in advance,
    Brett
    1968 Series IIa 88 w/ hardtop - SOLD
    1970 Series IIa 88 (parts car)
    M416 Trailer
    2008 Toyota FJ
    2009 Volvo C30
    1983 D110
    http://68landy.blogspot.com/2010/01/blog-post.html
  • albersj51
    • May 2010
    • 687
    Try pulling the choke. If it doesn't stall perhaps you're generator isn't keeping up? Of course the red charge light would probably be on as well. Mine does this if I driVe it a lot at night with the headlights on. I plan to do the alternator conversion very soon
    • usadventureracing
      • Sep 2008
      • 106
      Previous owner installed an alternator.
      M416 Trailer
      2008 Toyota FJ
      2009 Volvo C30
      1983 D110
      • Nium
        • Aug 2009
        • 400
        Vacuum readings
        If you are suspect of the vacuum here's a link to a site with explanations of using a vacuum gauge and the expected results http://moodle.student.cnwl.ac.uk/moo.../vacgauge.html
        Though it would probably run really crappy across the board if it was a vacuum leak but a hand held vac gauge can be helpful in diagnosing issues.
        Never hurts to check the low tension lead if your running a 25D4 distributor.
        Cheers!
        Walker
        1968 Series IIA-"Ronnie"
        88" SW, 2.25L Petrol, LHD
        • Lalo88DK
          • Nov 2009
          • 116
          I had exactly the same problem with my series III 2,25 petrol, I bought a new Zenith 36 IV Carburetter (poor quality copy from china/India) and that particular problem was solved. A lot of new problems came to life though .
          • usadventureracing
            • Sep 2008
            • 106
            Thank you for everyones reply, I checked with a vacuum gauge and I am at 15, so I think I am good.
            I ordered a new weber carb today.
            Brett
            M416 Trailer
            2008 Toyota FJ
            2009 Volvo C30
            1983 D110
            • gudjeon
              • 613
              Pull on the choke section of the carb back while it is idling. This may show the dreaded zenith warp if it dies doing this. I had a weird problem of it stalling when I stopped in reverse. Also, if it just won't idle, or dies quickly, the slow speed running jet may be plugged.
              Bon Chance!
              • NickDawson
                • Apr 2009
                • 707
                will it idle at other times? For instance, you can start it and just let it run?
                You said it dies at lights and stop signs, what about in the driveway?
                • usadventureracing
                  • Sep 2008
                  • 106
                  I can get it to idle only happens after I am driving and come to a stop.
                  M416 Trailer
                  2008 Toyota FJ
                  2009 Volvo C30
                  1983 D110
                  • scott
                    • 1226
                    how are your motor mounts? i recently had issue where the ambi would idle really high at lights. turns out the mounts were so wasted the the engine would move forward & backward enough to stretch or compress the throttle linkage
                    '64 Series IIA 88 Canvas Tilt
                    '68 Series IIA RHD Ambulance
                    '76 Spitfire 1500
                    • usadventureracing
                      • Sep 2008
                      • 106
                      Ok replaced the carb with a new weber and she is running good now. Now I just want to convert to a pointless ignition.
                      M416 Trailer
                      2008 Toyota FJ
                      2009 Volvo C30
                      1983 D110
