Galvanized Bulkhead - Dealing with Zinced up Hinge
  • amcordo
    • Jun 2009
    • 740
    Hi everyone!
    The hinges on the bulkhead that attach to the window flaps on the front (just below the windshield) are filled with zinc. I can only get drill in a bit because of the angle. Any suggestions as to how I can clear those out?
  • Linus Tremaine
    • 178
    they make
    Flexible drill extensions. I have seen a home made one used on a bulkhead. I am pretty sure you can buy one off the shelf at the store though.
    1968 Land Rover "Park Ranger" camper **SOLD**
    1967 109 **SOLD**
    NADA Dormobile #601 **SOLD**
    1965 IIA 88 2.5NA Diesel
    1963 Mercedes 300se
    1975 Volvo C303
    KJ6AQK
    • crankin
      • Jul 2008
      • 696
      That was a great area on mine to figure out what to do...
      I started out drilling the best that I could do so that i could at least have a solid hole all the way through....then ran a chain saw file in and filed the zinc away.
      Birmabright Brotherhood
      Clint Rankin - 1972 SIII SWB
      • HybridIIA
        • 100
        Check out the site below. Someone made a nice site describing the galvanizing process for his bulkhead. Check out the photos at the bottom of "bulkhead swap" page, they show a homemade flex drill bit.
        '62 109 - coil sprung
        '64 88 - coil sprung
        • Leslie
          • 613
          I drilled mine out, using my flex-dremel end.
          -L
          '72 SIII SW 88"
          '60 SII 88" RHD
          • lrdukdog
            • 321
            drill
            In the drill set I got from Sears there is a flexible arrachemnt for drilling 90 degree angles. It works very well. I believe they sell it seperatly as well.
            Jim Wolf
            • jp-
              • 981
              No need for special drill bits here. Very easy. Buy a long 3/16" Self drilling fastener with a 5/16" hex head. Put a flexible 5/16" driver on your favorite cordless drill and bam!
              If you are worried about the threads of the fastener damaging the hinge, just sand them off, so you are only using the drill tip of the fastener.
              67 IIA 109" NADA Wagon (sold)
