Thanks all!
I'll tell you what, if anyone is interested, I'll let this one go for $500. That's a heckuva deal!
I haven't actually used it yet other than bench testing. I took four trays of ice cubes from the freezer (not very much) and fill the cooler half way up with water. Using a computer fan (not much flow), the air coming out of the heat exchanger was 64F when ambient was over 90F With more ice, the ducting, and larger blower (250 cfm), it will be much colder. I built it for my 30 minute commute, but I expect it will last an hour or two. It's really proportional to how much ice you put in it. However, once the ice melts, that doesn't mean the cooling stops. I'll put it this way, it has an off switch.
There is a similar thing on instructables, but his has the lid open during use. Not only would there be a likely chance that you'd end up with a floor full of ice water, but you'd also humidify the air.
. You will definitely be cool, won't even hear the generator when driving,
