Hi, I have a 73 S3 with a broken handbrake. The lever moves back and forth but doesn't ratchet. Any ideas of what it maybe?
S3 Handbrake
Could it be that the mechanism that releases the brake is rusted/gunged up in the 'release' position?
Have you looked underneath or taken off the under the middle seat access panel to look and see if all the partas are there?
LaneRover1958 107 SW - Sold to a better home
Good idea about the middle seat access panel. I just bought this thing about a week ago so Im still learning my way around. I'll check it out 2 nite.Originally posted by LaneRoverCould it be that the mechanism that releases the brake is rusted/gunged up in the 'release' position?
LaneRover99 D1
73 Series III 88"
95 RRC LWBComment
more than likely the button on the top of the handle is froze, not allowing the teeth to mesh with the bracket,use some p b blaster to loosen it up.the spring and button should should work freely
its full of crud or rusted,good luck..
www.singingcamel.comLast edited by singingcamel; 04-09-2007, 10:37 PM.Comment
There is a bolt that sandwiches the handle closer to the base by the cross bar (LHD) This was loose on mine and I had the same problem. I tighted it and it ratchets again. The return spring behind the brake backing plate was also missing.1972 NAS Series 88 SWComment
Thats what it was, thanks!Originally posted by LH DriveThere is a bolt that sandwiches the handle closer to the base by the cross bar (LHD) This was loose on mine and I had the same problem. I tighted it and it ratchets again.99 D1
73 Series III 88"
95 RRC LWBComment
