Galvanized Body Capping & Riveting
  • Skeeball
    • Nov 2007
    • 63
    #31
    Momo and Disco2hse advise is spot-on
    I have done this twice using the correct Hammer rivets which are available in bulk from McMaster-Carr. For the visible body cappings use aluminum hammer rivets you will need a bucking bar and a cheap air hammer gun its not hard to install them correctly where the fixings are non-visible use aluminum rivets with aluminum mandrels.
    Have the body cappings hot dipped
    Easily...hit any heavily rusted/pitted areas with a grinder or sand paper easy does it any excess old paint or finish will be removed when the parts are re-dipped as they get an acid bath first.
    1964 Series IIa In progress
    1968 S IIa (Sold)
    1972 S III (Sold)
    1996 Discovery SE-7 (Sold)
    • NRutterbush
      • May 2010
      • 33
      #32
      Have you considered walnut-shell blasting? Crushed Walnut shells are commonly used as an abrasive blasting media to strip and polish aluminum and other soft metals. I haven't tried it, but I would bet that you could do it in place on the truck, remove the paint, and leave behind nice, freshly exposed zinc surface that could re-oxidize to a pretty fresh looking galvanic coating.
      Has anyone else tried this? I intend to soon, but it might be good to have some experienced advice.
      • ducttape
        • 169
        #33
        if you do shot peen, don't forget Merco Tape! http://mercotape.com/fliers/ShotPeen.pdf Proud sponsor of Team Italian Job and He-Man Racing.
        One would think there must be SOME Rover out there that could use my duct tape to hold it together, rather than as a masking.
        1967 Series IIA 88
