Weeping gas tanks
  • Burlsube
    • Jul 2010
    • 62
    Weeping gas tanks
    I have an Ex-Mod with two weeping gas tanks. The military style tanks seem to be extremely hard to source. I was wondering if anyone had any luck with any other ways to restore gas tanks?
    I know POR 15 makes a product. There used to be a company called Forever Rover that seemed to make them, but looks like they are out of business.
    Any thoughts?
  • SalemRover
    • Aug 2007
    • 310
    This was just discussed over at G&R.
    I am waiting on the POR-15 kit to address my weeping tank.
    • Burlsube
      • Jul 2010
      • 62
      Thanks. You mentioned a shop in MA that would restore them... What's the name? I'm on the South Shore.
      • SalemRover
        • Aug 2007
        • 310
        Roger's Radiator
        389 Riverside Avenue
        Medford, MA 02155-4932
        Get Directions
        (781) 395-7777
        They seemed straightforward in my conversation with them. I suppose if I didn't just buy a soft top for the 5 door I would be more inclined to go that route. If you don't know what Big Sky Rover's gas tank implies then just imagine your tank with a few extra bullet holes for authenticity. No extra charge for the bullet holes Im sure, but they do add to the character of an ex-mod rover.
        • jac04
          • 1884
          I had the same issue with one of the military tanks on my Lightweight, even though both tanks look like new on the inside & outside. I tried contacting Forever Rover as well with no response. See the discussion thread here:
          I still have my original two tanks, so if yours are heavily rusted send me a PM. Here are the tanks:
          Inside of the 'good' tank:
          Inside of the tank that weeps:
          • BGGB
            • Jul 2008
            • 83
            eastwood use to make a gas take repair that basically lined the tank with a plasticy stuff on the inside....im sure napa or autozone would make a kit similar, hope this helps
            • mongoswede
              • May 2010
              • 757
              I have coated a couple of motorcycle tanks with the kreem (think thats how its spelled). It worked well but I have heard of some people having problems. I did a very thorough job of cleaning the tank and using the rust remover before putting the coating in.
              • gudjeon
                • 613
                Clean inner part of the tank. Dump in a couple layers of Red-Kote and turn tank all around to spread it. Clean it out with your favourite solvent and a length of old dog chain and literally shake the crap out of it. Steam clean and use MEK or Methyl Hydrate to take care of any moisture. Make blanking plates and seal using old inner tube as gaskets. I applied low air pressure with a fitting in one to make sure it squished though any breaches while it cured.
                • JackIIA
                  • Dec 2008
                  • 498
                  Any thoughts?
                  My understanding is that John Gerling (sp?) stated the cost of stainless steel had become so expensive that he could no longer create products at a reasonable price. I was pretty charged up about his stainless breakfasts.
                  1970 88 IIA
