Ok, I am trying to install a petronix everything is hooked up but I cannot get the magnet on. Does anyone have any advice tried for 2 hours. I bought the LU-143 and have a 45D. Thanks
Installing a Petronix
1968 Series IIa 88 w/ hardtop - SOLD
1970 Series IIa 88 (parts car)
M416 Trailer
2008 Toyota FJ
2009 Volvo C30
1983 D110
http://68landy.blogspot.com/2010/01/blog-post.htmlTags: None -
Do you have a 'real' Lucas 45D or the aftermarket replacement? I've heard that the Pertronix doesn't work with the aftermarket 45D replacement distributor.
Also make sure that you have the correct Pertronix unit. The LU-143 is for the Lucas 45D with RED points. Their catalog shows the LU-144 for the 45D to replace the BLUE points. I remember the magnet wheel having some casting 'flash' around the bottom that I had to knock off with a small file, but it fit fine otherwise.
Also, check ou the following site - especially Note 1 under the Lucas Pertronix listing:
Bluehost - Top rated web hosting provider - Free 1 click installs For blogs, shopping carts, and more. Get a free domain name, real NON-outsourced 24/7 support, and superior speed. web hosting provider php hosting cheap web hosting, Web hosting, domain names, front page hosting, email hosting. We offer affordable hosting, web hosting provider business web hosting, ecommerce hosting, unix hosting. Phone support available, Free Domain, and Free Setup. -
"I've heard that the Pertronix doesn't work with the aftermarket 45D replacement distributor."
I've not heard that & hope you are wrong, I have an aftermarket 45D and plan on going Pertronix after my rebuild is complete.
Has anyone here installed a Pertronix on a "knock-off" 45D?04 Disco, Gone-Disco died & so did mine
'72 S3 88 - Leakey & SqueakyComment
^^Contact BGGB and ask him what the issue was.
Thanks for the info. I am not sure if it is the aftermarket 45D. I called the location I purchased it from and they told me to call Pertronix directly. We will see. Yes I have the correct part number.......I had red points. I will update when I find out any more info.1968 Series IIa 88 w/ hardtop - SOLD
M416 Trailer
2008 Toyota FJ
2009 Volvo C30
1983 D110
http://68landy.blogspot.com/2010/01/blog-post.htmlComment
OK, here is an update.....everything is installed and working great. In order to install the magnet I had to file the inside. I just filed a small amount away at a time and finally get it to seat. Runs and starts like a champ. Hopefully it will stay this way for a long time.1968 Series IIa 88 w/ hardtop - SOLD
M416 Trailer
2008 Toyota FJ
2009 Volvo C30
1983 D110
I install the pertronix last weekend but now I am over heating. Could this be the cause or is it more likely a water pump issue. Thanks1968 Series IIa 88 w/ hardtop - SOLD
M416 Trailer
2008 Toyota FJ
2009 Volvo C30
1983 D110
Yes, did you time it after you installed the pertronix? I think the instructions (atleast mine did a few years ago) stated to retime the vehicle after installing it. Or it could just be a coincidence and be a bad waterpump, thermostat or radiator.
How's that for a positive answer!Jason
Thanks for the info. I did set the timing and I am going to check it again. If that does not work I am going to change the thermastat then the waterpump. Thanks1968 Series IIa 88 w/ hardtop - SOLD
M416 Trailer
2008 Toyota FJ
2009 Volvo C30
1983 D110
5 years later
I'm looking at running a Petronix electronic ignition after I finish freshening up the motor. I was wondering if the Petronix would run a little hotter and if it required (or ran better) with a different spark plug.
I might run a Rochester carb too; undetermined at this time.
I know that restoring a series isn't a budget friendly job but the cost of the Petronix seems a bit high considering the parts involved. I think I read about the Brits building their own electronic ignitions out of parts form "radio shack" type stores. I mean, Land Rovers where designed and built in a barn after all...Comment
Check hotspark for prices. The quality seems fine, and the price is much better. Especially if you have a dizzy in good condition, and you are just putting the parts into your existing dizzy.Bad gas mileage gets you to some of the greatest places on earth.Comment
I'm going to give the Pertronix a try on my 1974 SIII. Please stand by for questions
. My distributor has been killing me lately!
