I am looking for the engine mount that bolts to the chassis, not those that bolt to the engine. It is on the passenger side of a LHD for a 2.25 petrol. Our hosts will not have them until mid Sept. and I would like the engine in the truck in the next 2 weeks. Figured I would ask here first. Thanks!
Anyone have extra engine mount
The rubber mount with a stud on each end? If so I should have a few.
Edit: I re-read the post and you are talking about the small steel mount that is attached to the chassis with 2 bolts/nuts, correct? I'll take a quick look, but I don't recall seeing one in my collection of parts. -
I put my series 3 drive train back into the chassis using the later ones for a disco. The studs were a little bigger in diameter but it was pretty easy to make things fit.Comment
Yes it is the small steel mount that I need not the rubber. It goes between the chassis and the rubber only on the passenger side.1973 NADA 88Comment
I've had a rummage through our used parts, sorry, we do not have one either
Les Parker
