Tricks for removing doors?
  • bullstanky
    • Dec 2007
    • 119
    I'm trying to take the doors off of my S3 to replace the sagging hinges, but the bolts going to the bulkhead are frozen and I can't seem to get much torque with my Phillips head screwdriver. Any tricks or special tools I should know about that might help?
    '75 SIII 109 Diesel - I'm in deep.
    • 400
    You can try an impact screwdriver that you strike with a hammer. Sears has one for around $50.00. I've had to drill out very stubborn screws just to remove the hinge from the bulkhead, and then bend the nut clips to remove them.
    • Bertha
      • Nov 2007
      • 384
      Drill them out and buy new
      1971 88 (restored and as new)
      1967 88 (the next project)
      • stomper
        • 889
        aside from an impact screwdriver, I have had some luck with using a screwdriver socket. it is basicly a socket with a phillips head driver on the end. Once you fit it to a rachet or a breaker bar, you can get a considerable higher torque on the head. The problem is pushing inward on the socket to keep from stripping the head of the screw. it is cheaper than an impact driver if you are strapped for cash, but the impact driver has a lot of uses on an old rover.
        • amcordo
          • Jun 2009
          • 740
          I've used a giant flat head screwdriver and beat it with a hammer, then pushed the screwdriver very hard while turning very slowly. It work for me. May have to beat them hard and often though.
