Hello Everyone,
I have an interesting issue, one I never expected to have with a rover.
I bought a Craigslist find, 61 88" up in the mountains. It had not been registered or run since 1969. I stripped it to the bare chassis, thinking that I would repair the rust and paint it with POR 15 or similar chassis paint. What I found, after dis-assembling the entire Rover, and scraping all of the asphalt / rubber undercoat from the chassis, was almost all of the original black paint from the factory.
I still plan to have the chassis cleaned / sandblasted, to remove the little surface rust that is there, but what to do next is a question. There is a local shop that can hot dip galvanize the entire chassis. Cost is not an issue. The blasting shop has suggested powdercoating on other projects, but he does that for a living, so I'm sure that suggestion makes sense to him.
The real question: Will galvanizing an original chassis be effective? There seems to be a lot of spaces within the chassis tubes that will not be reached by the blasting, and thus not cleaned well enough for the hot dip to coat them effectively.
Are reproduction chassis designed differently, to allow effective galvanizing?
Should any reinforcements be made prior to treatment?
I'm looking for any and all opinions here.
No the rover is not for sale.
Thanks,
Nate
'61 88" Diesel
'63 88" Petrol
"I'll let you know when one is running!"
Thanks,
Nate
'61 88" Diesel
'63 88" Petrol
In progress
