Went to refit my Fairey OD and it won't go all the way in. It is 'sticking out' about 1/2 an inch. I've tried all the suggestions in the manual from George's site (turning the e-brake drum while fitting, low range, red shifter in neutral while maingear in first, etc.). I've also tried to lever it in with a 2x4 and given it a moderate amount of muscle.
The one thing I have NOT done is bought a Fairey Overdrive special lockwasher for the castellated nut. Is that the problem?
For those who have pulled and refitted their Faireys, have you switched out that locktab with one from George as opposed to the OEM one? Alternative, have you NOT switched out the original style locktab washer and had NO problems fitting the OD?
