What order do you tension the top and middle bolt on a series 3 windshield retainer?
Properly setting the folding windshield retaining catches?
Do you mean the nuts on the stud that goes through the tab on the inside of the windshield frame? If so, I'm not sure you have much choice. You need to adjust the nuts on the catch stud to get the proper fit between the windshield frame and the door top. Once you get proper fit you can tighten the 2 nuts to jam them.Last edited by jac04; 08-21-2010, 06:44 PM. -
There really is no tension. The windscreen folds down and up.
I think he is talking about the catch windscreen on the inside cab that you undo to flip the windscreen down. The way I set those was to place the top on and make sure that the holes on the windscreen lined up with the roof. Stick bolts in those holes so that its sturdy... and the windscreen is in place.
Then tighten those catch windscreen nuts.
This guy is what i am talking about...
Tighten the bottom nuts first...tighten to the bottom of the windscreen frame. Then cinch down the top nut.
Birmabright Brotherhood
Clint Rankin - 1972 SIII SWBComment
