"Barn Find" locked frozen wheels
  • crankin
    • Jul 2008
    • 696
    #16
    Originally posted by kwd509
    I am also pursuing a 2a recovery this weekend- IN east tennessee have similar concerns with moving the long dormant beast. But am I correct in understanding that if I disengage the engine from the drive train, I shield the engine from the forces of moving it and can then literally drag it if necessary with 2 come-alongs.... If that is the case I want to focus my contingency planning on getting it in neutral or disconnecting the drive train- which looks pretty easy - four 9/16" bolts. Am I missing something here?
    Like suggestions for PB blaster and mystery oil.
    Where at in E. Tennessee. I might know of the truck... I am from a town outside of Chattanooga named Cleveland.
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
    • LR Max
      • Feb 2010
      • 315
      #17
      Originally posted by crankin
      And don’t listen to amcordo…all he thinks about is women and making his land rover into a Mad Max Beyond Thunderdome vehicle.
      2 things:
      A) If you are in ATL, we must have a drink.
      B) I beat you to it: my truck already says "Mad Max" across the back
      @ kwd509, For your issue, I'd say just try to put the transmission in neutral. If not, then try transfer case neutral. Shouldn't mess up anything for the short distance you are moving it. If worse comes to worse you can disconnect the rear driveshaft.
      • Terrys
        • May 2007
        • 1382
        #18
        four 9/16" bolts.
        They are 3/8"BSF.
        I have moved dozens of rovers that have been sitting a LONG time, and never found one with a stuck ebrake, simply because they are plenty greasy inside them. Stuck brake levers, Yes, but not the drum/shoes. Nor I have I ever seen a wheel bearing sieze from sitting. Getting them to move really depends on the ground they are sitting on and how round the tires are. A half flat tire, with any age, is hard as a brick and doesn't willingly roll.
        If it was left in gear, it may take a bit of tugging, especially with a S3, but never any difficulty putting the TC in neutral. A few planks may make rolling easier if you're trying to move across soft ground.
        • jopa
          • 43
          #19
          Frozen wheels...not too hard to free up without alot of fuss...Jack up the truck safely, take off the hub drive flange, loosen up the hub nuts...then shake the tire/wheel- even employ a BFH. I had to do this to a parts car that sat in a field for 30 plus years...it had sank almost up to the chassis in the soft soil. Terrible day....it was raining- 33 degrees outside...worst recovery Ive ever done...but freeing up the wheels was the easier part of it. J
          • artpeck
            • Dec 2009
            • 368
            #20
            I am really appreciative and rather amazed by the collective chiming in here on this issue. Friday is the big day and I have a lot more confidence in going after this. Will let you all knownhow it goes and post a picture or two as well. Keep the ideas coming.
            • kwd509
              • Aug 2010
              • 190
              #21
              It is in Lancing, Tennessee. I don't think it is near Cleveland TN-----
              On a farm where I grew up........
              google street view shows it sitting in a pasture- I haven't been there in 24 yrs.
              Son saw the image compared it to the earlier 'before' photo from childhood and pleaded- Let's get it- after all we are going right by with a truck......
              I'm keeping fingers crossed this can be done gracefully.
              • kwd509
                • Aug 2010
                • 190
                #22
                To LR MAx
                " 'd say just try to put the transmission in neutral. If not, then try transfer case neutral. Shouldn't mess up anything for the short distance you are moving it. If worse comes to worse you can disconnect the rear driveshaft."
                That matches my thoughts exactly........
                being a mechanical beginner I'm thinking of all the unexpected things that can happen.
                • kwd509
                  • Aug 2010
                  • 190
                  #23
                  Artpeck,
                  I didn't intend to hijack the thread- but the input given to you was really quite helpful, and I became perhaps too enthusiastic.......hope that input given in response to my queries was helpful to you. I look forward to seeing your pictures. Good luck.
                  • BobJones
                    • Jun 2008
                    • 61
                    #24
                    I had the same problem at the beginning of my restoration, sat in a barn for years, 2 wheels totally locked up. I didn't want to tow it out and pull on the frame too much, so we freed the wheels first. One of the biggest pain in **s jobs of the whole restoration! I hope yours goes better. First I inflated the tires and I did pull it out of the holes it sank into, 5' or so. I then jacked it up, Used a torch to heat up the locked drums, beat the he*l out them, then dropped it and pulled it out of the barn. It dragged about 5' then all wheels turned free (relatively), noisy but moving. Getting the drums off will be sooooo much fun! But you say the frame and bulk head are good so you will have alot of fun and headaches but more fun then anything else. Good luck
                    • artpeck
                      • Dec 2009
                      • 368
                      #25
                      No worries at all about highjacking the thread. All interesting. As a side bar thankfully my rescue is sitting comfortably on a concrete pad rather than axle deep in a pasture. Thanks sounds romantic but ugly. Mine is also one that is staying in the family as the truck currently belongs to my brother in law's wife's uncle if that makes sense.
                      • kwd509
                        • Aug 2010
                        • 190
                        #26
                        That counts for staying in the family. Looking forward to pictures.
                        • NRutterbush
                          • May 2010
                          • 33
                          #27
                          Where is it?
                          Artpeck,
                          You mention Northern CA. I'm in the general area. What city is your project in?
                          -Nate
                          • kwd509
                            • Aug 2010
                            • 190
                            #28
                            Originally posted by Terrys
                            They are 3/8"BSF.
                            Your correction raises a very basic rover question......so I'm really glad you raised it.
                            you correct me on the size of the drive shaft bolts. I'm new to this and have yet to have a good grasp on what tools I'll need. I recently studied a rover belonging to a friend, who has used his 2a to plow a very tough driveway and for other farm chores, He has kept it going for years and when I asked him the drive shaft size, he indicated he had very few specialized tools and managed fine...... and then he noted that he had used a 9/16". I climbed under the truck and confirmed it seemed to fit well (there was a little play but I might not have noticed if I hadn't been attentive).
                            How specialized are the sizes and tools?
                            thanks.
                            • artpeck
                              • Dec 2009
                              • 368
                              #29
                              The truck is currently in the sacremento area. I am in the bay area.
                              Art
                              • Tim Smith
                                • 1504
                                #30
                                When you are pulling it, if you happen to see a wheel going the opposite direction then it is stuck in gear. Worst case scenario is, pull the drive shaft and you are good do go. Otherwise, get it in neutral and you should be all set.
                                If there is a wheel that is stuck on and not moving in either direction, then try wrapping the rim with a large hammer or a sledge. Not so hard as to bend the rim but hard enough to try and bump the drum against the shoes and force them to come back in and free the wheel. If that doesn't work then you might want to jack up the offending wheel, take the wheel off and hit the drum at 10 o'clock and 2 o'clock. Maybe it's 3 and 6 o'clock but again the theory is to knock the drums back in. If you get in this deep, then don't worry about cracking/shattering the drum as it's most likely going to be on your list of replace items on the truck.
