wheels and tires.. 245/75R16?
  • PavementEnds
    • Feb 2010
    • 84
    Ok, please don't shoot me, but I did go back through all of the old threads on wheels and tires (2x, even) and didn't see an answer to my question. I have 15" wheels that had tubed tires and tried to mount a tubeless but the wheels are too rusted to hold air. Sand blasting and powder coating (at least here in Austin) cost about the same as a new 16"x7" wheel from Gulf Coast Rovers. This rig will be my forest service road runabout so I am looking at retreads from Tread Wright, and am wondering if anyone has any experience with a 245/75R16? I worry that this wide tire (8.2" tread width) will rub on turning. TW also has 235/85R16 (tread width 7") that look good but these builds are several weeks out. Any thoughts? Oh, the work on my rig continues. Was out of country for 3 months and on my return it started right up!
  • SGS714
    • Jan 2007
    • 83
    I put 245/75r16 on my rig and have had no problem at all.
    ________________________
    67 Series II
    93 D110 NAS 327
    94 2x D90 NAS #'s 1076, 1181
    95 3x RRC 2-SWB, 1-LWB
    • rwollschlager
      • Sep 2007
      • 583
      If your truck is still undergoing a rebuild I recommend waiting for the 235/85/16's. They are tall enough to provide decent clearance, yet narrow enough to maintain a turning radius under half a mile. I was looking into a set of treadwrights myself a while ago and in my research I heard nothing but good things about them. The only reason I never purchased a set myself is I found a set of tires cheaper on craigslist.
      I hope this helps and let us know if you order a set!
      -Rob
      72 SIII 88
      67 SIIA 109
      82 SIII Stage 1 V8
      • NickDawson
        • Apr 2009
        • 707
        I still can't wrap my head around tire sizes...
        but for what it is worth, I put on 235/85/16s and they rub just a little on the tightest radius turns. I'd think that anything wider might be a problem.
        • jac04
          • 1884
          Originally posted by NickDawson
          ...they rub just a little on the tightest radius turns. I'd think that anything wider might be a problem.
          Remember that he is planning on using aftermarket wheels. Depending upon the wheel width & offset, the inside of the wider tire may be in the same place (or even further away from the chassis) as the stock wheel & narrower tire.
          • Andrew IIA
            • Feb 2008
            • 327
            Well said. My 88" has been running for years with 265/75R16 on D110 steel wheels. This is orig. equip. NAS D90 size tire I believe. Lots of flotation; good for sand.
            Andrew
            '63 SIIA 88" SW
            • LR Max
              • Feb 2010
              • 315
              I'd say stick with 15" rims and tires. Overall will be cheaper and more off road-biased tires available...a lot of used tires too.
              Think of this: A set of 15" rims, painted to match your truck and then a set of 30x9.5x15 BFG ATs. They will be about the same as if you went 245/75/16, but you'll save well over $200 bucks
              I say this since price seems to be a big issue for you.
              • rejeep
                • Apr 2010
                • 420
                X2... full lock I rub spring
                1971 SIIa 88" NAS Dauntles V6
                1974 SIII 109" RHD
                • PavementEnds
                  • Feb 2010
                  • 84
                  Thanks so much for the replies. Site sponsor had two offers on used 16" wheels and tires this past week but they went FAST! I called all of the shops I could find in Austin TX to sandblast and powdercoat the 15" wheels I've got but most shops were ~$100 per wheel, which strikes me as a lot -- Gulf Coast Rovers lists the 16"x7" rims, 4-1/4" backspacing, for $89 each (cheap shipping to Austin from Houston). They also list 15"x7" rims but these are way out on delivery times (months) -- I have not been able to locate any other 15" rims with our 5 on 6.5 pattern. Any ideas on sources welcome. My old tires are nearly shot -- all I can do is putter up and down my alley, ha ha -- don't want to get too far from my driveway in case they blow!
                  • TriedStone
                    • Apr 2007
                    • 81
                    Might be worth a trip up I-35. Here in OKC I pay 20 / wheel for blast and 20 / wheel for powder coating.
                    • PavementEnds
                      • Feb 2010
                      • 84
                      TriedStone -- can you PM me the name of the outfit you use? OK is Ok by me!
                      • yorker
                        • 1635
                        It definitely shouldn't cost that much to blast/refinish the rims. How rusty are they really? If they are riveted construction the rivets often leak, use a wire brush and paint them yourself. You can use bead sealer too.
                        Land Rover UK Forums
                        • J!m
                          • 295
                          And I have an original 15" wheel that is is nice shape if you need a spare....
                          It is (as you know) heavy, so shipping may be a bit pricy...
                          1995 110 Regular
