My 72 Series 3 with 2.25L Pertol has been giving me fits lately. She will occasionally lose power in various situations (both hills and relatively flat roads). When this happens, she backfires when I hit the gas and nearly stalls when I slowly push the accelerator to the floor. If I get her moving, she randomly backfires (softly, not a cannon shot). I usually have to limp along with the choke engaged and feathering the clutch to get her to move. The crazy part is that it stops after a while (variable time spent swearing and asking why), and the truck runs great again.
I have recently gone through the valve/timing/carb tune-up route after changing the spark plugs, all seemed to be in proper order. Have been running a Petronix ignition for some time now without issue, and the sediment bowl on the fuel pump seems clear (will be checking that again tonight). There is an line filter in the fuel line just before the carb. I am also going to give the carb a good looking at tonight to make sure its clean/clear (Weber 34ICH). I also tightened the bolts on the exhaust and carb to see if a slight air leak might be the cause. No obvious holes along the exhaust either.
The return to normal function after these episodes is confusing. Any thoughts about potential causes? Vapor lock (truck has not been running too hot lately)? Other timing issues I should be looking at (timing chain)? Are there parts I should uniformly replace to eliminate potential problems while troubleshooting?
Thanks,
Patrick
Thanks,
Patrick
