NEED HELP: Parts Indentification
  • RoverForm
    • Jul 2010
    • 348
    I have a box of parts, and I'm not sure of their purpose.
    Help...
    Fig. 1
    Fig. 2
    Fig. 3
  • RoverForm
    • Jul 2010
    • 348
    Need Help: Parts Indentification
    Fig. 4
    Fig. 5
    Fig. 6
    • RoverForm
      • Jul 2010
      • 348
      Fig. 7
      • Jim-ME
        • 1379
        Figure 4 is a clip which holds the cloth strip to the breakfast (radiator panel) which buffers the bonnet (hood) from the breakfast. Figure 6 and 7 appear to be the sealing washer and gasket which seals an OD shifter where it comes thru the transmission tunnel. That is assuming that #7 is made out of rubber.
        Jim
        • Terrys
          • May 2007
          • 1382
          1 looks like a Jerry Can Cover, 3 is a condensor, and 5 are points for a 25D.
          • scatterling
            • 183
            2. looks something like a windshield washer nozzle. Just a guess never seen one quite like it.
            Neil Hanekom
            '73 LHD 88
            '99 D1
            • Cutter
              • Feb 2009
              • 455
              yep, I have two of those nozzles on the hood of my SIII. There are also two stalk mounted nozzles on my bulkhead, wasn't sure which was original.
              • RoverForm
                • Jul 2010
                • 348
                Thank you!
                Nice! That was quick. Post a few pics in the evening and have all the answers by morning!
                So here's what I have:
                1. Jerry Can Cover
                2. SIII windscreen washer nozzle.
                3. Condenser
                4. Cloth clip for breakfast/bonnet
                5. Points for a 25D
                6. OD shifter sealing washer
                7. OD shifter gasket (or) turn signal gasket?
                What is a 25D?
                Jim
                Yes, Fig. 7 is rubber.
                • mongoswede
                  • May 2010
                  • 757
                  Originally posted by RoverForm
                  Fig. 7
                  Looks like a gasket that might go behind a turn signal.
                  • Terrys
                    • May 2007
                    • 1382
                    What is a 25D?
                    Lucas distributor
                    • stomper
                      • Apr 2007
                      • 889
                      A 25D is a type of distributor. Different distributors, or "Dizzy" for short, use different types of points, rotor buttons, and dizzy caps. The ones you pictured (the condensor too) go to a 25D dizzy.
                      • Terrys
                        • May 2007
                        • 1382
                        The round ones sticking out of the bulkhead are original, not the chrome ones. Those look more like some British Sports car might have.
                        • Cutter
                          • Feb 2009
                          • 455
                          maybe I'll hook all 4 up at some point and really give the windows a good soaking
                          • RoverForm
                            • Jul 2010
                            • 348
                            Looking for door side steps...
                            I had these on my 109, would like to get a set of three for the 88.
                            Anyone seen them around?
