1983 SIII Camel Trophy Information
  • crankin
    • Jul 2008
    • 696
    I'm falling in love with this. So far this is all the information (from various forums) that I have found on the 1983 CT. Can anyone add to the specs and setups on the SIII SWB and on the support vehicles? I am particularly interested in the light guards and rack....any ideas on these?
    Sandglow paint, semi-gloss black (local auto paint store). Body is Sunglow, front bumper painted black. The SIII Camel trophy Land Rovers did not have roll bars, snorkel or pioner tools mounted outside. The originals were German spec Similar looking to US spec) with 2.25L diesel engines.
    Small Camel Trophy country team stickers were mounted to left hand rear window STK98 (see picture near top of this page)
    Steel 16 inch wheels: ANR4636PM (5-1/2 " wide) ANR1534PM (6 " wide). 750X16 tires were mounted.
    Sand ladders: GMN041 (pair): mounting kit 4-STMB product description
    Genuine Land Rover work lamp was mounted to rear RTC8921AA
    Genuine Land Rover 'D' recovery rings was mounted to top of front bumper 267950
    Front of roof rack mounted a pair of 7 inch dia. lights 900DDCS Product description
    A pair of rectangular fog lamps were mounted to the top of the bumper PRC8238 Product description
    Both Waren 8274 and Ramsey DC-200 winches were used.
    Jerrycans: gas GJC20, water 20WATERBLU, spout semi flex GJC002
    Could only imagine the pain from the landing on this one...
    Birmabright Brotherhood
    Clint Rankin - 1972 SIII SWB
  • RoverForm
    • Jul 2010
    • 348
    The Series 3 was only ever used on one event which was Zaire 1983, and probably represented the most rag bag mix of vehicles ever seen on the Camel Trophy. The vehicles were all 2 1/4 litre diesel station wagons in both 88” and 109” wheelbase versions. Team vehicles were all 88” versions.
    All were painted in sandglow with a black and yellow Camel Trophy decal on each side door, and a Land-Rover text down the side, which appears to be a cut down version of the Land-Rover V8 decal. Pressed aluminium Camel Trophy plates were fitted to the front bumper, which was painted black. A small Camel trophy plaque was fitted adjacent to the rear door, while a small Camel Trophy sticker in the top RH corner of the windscreen and to the LH rear window denotes the convoy number.
    Wheels were standard 5.5Fx16 finished in Limestone, all of which were fitted with 7.50 x16 tyres, although at least three types were used. Some vehicles were shod with Dunlop T29A Trakgrips, some had Michelin XZY radials, whilst others had bar grips.
    From the bumper up, all had auxiliary lights above the bumper, some of Lucas manufacture (as fitted to the Series 3 County) whilst others had lights of Hella manufacture. A number were fitted with framed mesh guards mounted to the bumper, and braced to the wing whilst others were not. In all cases these guards were fitted, front Jerrican mounts were also utilised. A roofrack was mounted on the 88” models with a rear door wheel carrier attached to it, which does not appear to have been fitted to all the 109s, although even these are not all the same. The roof racks had one extra Hella Rallye 1000 lamp mounted each side protected by weldmesh fitted to the front of the rack. Steel PSP was fitted to the sides of the racks. Rear lights were protected by the standard wire mesh basket lamp guards.
    Winches included the Warn 8274 and the Ramsey DC-200 mechanical drum winch. Lifting and towing rings were fitted above the bumper and a rudimentary steering guard below. In at least one photograph the vehicle pictured can be seen to have a military spec bumper, whilst others did not. Some had Fairey freewheel hubs, some did not.
    There were no fittings for pioneer tools, no roll cage and no bull bars. That aside it must be said that the Series 3 has a certain charm in its simplicity, and managed to go the distance without the later “essentials”.
    It should be remembered that when this event was staged Camel Trophy had only been going three years and that Land Rover were not a sponsor. This probably goes someway to explain the highly varied nature of the vehicles.
    Unfortunately only very few of these early vehicles still exist, the majority having been broken up long since. One famously went up in smoke on the event, but this was actually as a result of an accident a journalist had with a petrol stove, rather than a vehicle fault.
    Here are the detailed technical specifications for the Land Rover Series III.
    ENGINES
    Type: 4-cylinder in line
    Diesel
    Capacity: 2,286cc
    Bore x Stroke: 90.47 x 88.9 mm
    Valves: Overhead, 8
    Compression Ratio: 23:1
    Fuel Injection: CAV, indirect mechanical.
    Max. Power: 62bhp@ 4,000 rpm
    Max. Torque: 103 lb-ft@ 1,500 rpm
    TRANSMISSION
    Type: Four-wheel-drive, or rear-wheel-drive, with choice of High or Low range
    Gearbox: Four-speed manual gearbox, synchromesh on all forward gears
    Clutch: 9.5 inch single dry plate.
    Ratios
    Top: 5.396
    3rd: 8.05
    2nd: 12.00
    1st: 19.88
    Reverse: 21.66
    High-range step-down: 1.148
    Low-range step-down: 2.35
    Final Drive: 4.70
    Suspension and Steering
    Front: Live axle, by half-elliptic leaf springs, telescopic dampers.
    Rear: Live axle, by half-elliptic leaf springs, telescopic dampers.
    Steering: Re-circulating ball
    Tyres: 600x16 cross-ply OR 750x16 cross-ply
    Wheels: Steel disc, five bolt-on fixing
    Brakes
    Type: Drum brakes all round, hydraulically operated. Vacuum servo assisted as optional.
    Size: 88: 10x1.5 inches drums all round
    109: 11x2.25 inches drums all round
    Dimensions
    Track: 88: 51.5 inches front and rear
    109: 52.5 inches front and rear
    Wheelbase: 88 inches (Short)
    109 inches (Long)
    Overall Length: 88: 142 inches
    109: 175 inches
    Overall width: 66 inches
    Overall height: 77 inches minimum
    Unladen weight: 88: 2,953 lbs
    109: 3,301 lbs
    Diesel 4-cyl: add 144lbs
    Seating Capacities: 88: 3
    109: 3
    88 Station Wagon: 7
    109 Station Wagon: 10/12
    88 'County': 6/7
    109 'County': 12
    109 V8- 10/12
    and don't forget this gem:
    • RoverForm
      • Jul 2010
      • 348
      Also...
      Maybe this has been discussed ad nauseum, or maybe I just need to vent... but does anyone here truthfully feel that the G4 is as representative as the Trophy?
      No disrespect to any members who have done the G4, but from what i've seen it appears to be more of a car show/reality show than a challenge.
      I mean just compare the terrain and activities:
      Camel Trophy: Sumatra, Papua New Guinea, Zaire, Brazil, Borneo, Australia, Madagascar (the first north-south crossing) and Sulawesi before returning to the Amazon, Siberia and the USSR, followed by Tanzania, Burundi, Guyana, Argentina, Paraguay, Chile (the "Road to Hell" event), Belize, Mexico, Guatemala, El Salvador, Honduras, Kalimantan and Mongolia. That's some sough stuff right there.
      For instance the 1995 Central America finale in Mundo Maya, two Discos are disabled and have to be pulled through a river by the participants, totally submerged.
      Watch from 08:00
      G4: Thailand, Laos, Brazil and Bolivia and included athletic activities such as mountain biking, kayaking, rock-climbing, abseiling, trail running and rope work? This sounds more like a yuppie holiday than a challenge. At least the partnership in 2007 with LR G4 Challenge and the Red Cross and Red Crescent Societies would have potentially generated more than £1 million from future challenges, but whoops, it was canceled after the 2007 event.
      The G4 just doesn't have the same grit. Too polished.
      Is there anything like the Trophy these days?
      I think not... Maybe the G4 should see what Iain Chapman is up to.
      • Wander
        • Jan 2010
        • 260
        Are you doing a CT clone build crankin? If so-sounds like a cool project. I wonder why they did not fit snorkles to the rigs in 83 as they had been fitted to LR's for a while in similar places. Great pictures-that leaping 88-OUCH!
        RF- I don't think the G4 was ever meant to replace the CT but rather it was a challenge and a marketing tool. By adding the various other events it appealed to the multi-sport interest that is still popular. The G4 Disco's are impressive but not as impressive as the CT rigs. I've had the chance to look over a G4 Disco II and a CT110 at the same time-very different, but both impressive rigs. The 110 was a support vehicle used in Mongolia.
        64 IIa 88
        94 Discovery
        06 Toyota 4R (DD)
        ~Matt
        • amcordo
          • Jun 2009
          • 740
          They're going about it wrong.
          With all the Camel Trophies it's been proven that the LR can handle pretty much any offroad challenge. A more accurate modern Camel with our cars wouldn't be through the Sahara, Siberia, or the jungles of the Congo. Rather, it would be a marathon through the US Interstate system - how many of our cars would make it 3,000 miles on that without being pushed off the road by an angry fast driver?
          • crankin
            • Jul 2008
            • 696
            No. But there are elements to the CT rigs that I like and probably will implement some of them on mine. I just wanted to see all the information on them.
            • LaneRover
              • 1743
              The amazing part is that a heavily laden diesel made it off the ground!
              • Wander
                • Jan 2010
                • 260
                Yeah, even the portly, pasty english kid can jump...a little.
                64 IIa 88
                94 Discovery
                06 Toyota 4R (DD)
                ~Matt
                • LaneRover
                  • 1743
                  That's why they keep the sweets up high - incentive
                  • TJR
                    • 279
                    Great pics.. !! Thanks for sharing...
                    certainly better detail than this video..which is all I had ever seen from the '83 CT
                    • Boddington
                      • Jan 2009
                      • 31
                      Awesome film! I've never seen that before. Is there a longer video?
                      • LaneRover
                        • 1743
                        Interesting take on 'The Good Bad and the Ugly' for the background music.
                        • ducttape
                          • 177
                          great thread, great video
                          1967 Series IIA 88
                          • Leslie
                            • 613
                            This photo (of the incident in the video) seems to belong here, given it is a SIII CT....
                            -L
                            '72 SIII SW 88"
                            '60 SII 88" RHD
                            • luckyjoe
                              • 335
                              Sadly, that burning SIII was a CT 109"
                              Tom P.
                              1965 exMoD 109
                              1995 RRC LWB w/EAS
