Hold it right there! Anyone who takes a fender or sideskin off a LH drive Series or Defender to change a clutch master cylinder is a masochist. It is far far easier to remove the brake pedal and then the clutch pedal, clean everything up, repair and put back. Six 5/16 bolts each pedal and you can undo them with a i/2 socket. Room to camp in. Of course you have to disconnect the brake line but as you are doing this at the highest point it is nothing to re-bleed the brakes.
Ray in Vancouver
Ray in Vancouver
! I'd say anyone who does not remove the wing for a MC replacement/service is a masochist. I ended up spending a couple hours last year trying to replace my MC with the advice that you don't have to remove the wing. In reality, if I had just attacked the wing and taken it off (5-10 minutes) then I would have had no trouble getting my less-than-nimble fingers in to the small corner to get that MC out. This way you don't have to bench bleed the brake MC which (for me) always turns into a messy, castrol-wasting affair.
